Activity Forums Zaxwerks Can I use a movie with invigorator
  • Can I use a movie with invigorator
    Posted by Xeonxeon on November 2, 2005 at 3:18 am
    I want to creat a tv screen using Invigorator …. and I cann’t add movie to invigorator as a material in it .. so how can i do that ??? because when I use the movie in another layer .. it dosen’t fit the invigorator layer especially in camera animation …please I want some help … thank you
    Serge Hamad replied 20 years, 10 months ago 4 Members · 3 Replies
  • Malcolm Thorpe
    November 2, 2005 at 3:28 pm
    What comes to mind first is this: Import the video into your After Effects project, assign it as a layer map and map it to a flat solid inside Invigorator. Unless I misread, this should work and keep your video inside 3d space
  • Glenn Moore
    November 2, 2005 at 11:57 pm
    That’s it exactly. Unless I misunderstand your dilemma, you really only need to create your TV in Invig to generate a 3D effect. The movie is in another layer that can be placed onto the screen. The movie layer would be above the invigorated tv screen. You should experiment with the setting to get a more realistic look. You don’t want it to look too unrealistic. You may want to have a hint of tv lines (there are tutorials on that all around (including Ayato’s site) ) to give it a more real feel. That’s my .02 Euros.
  • Serge Hamad
    November 3, 2005 at 12:05 am
    Layer mapping is the answer as already mentioned. Just keep your object/TV once you draw it in IL at the same aspect ratio then your movie clip.
    Salut.
    Serge
