Activity › Forums › Storage & Archiving › Can I use a Lacie AC adapter with a G Drive?
  • Can I use a Lacie AC adapter with a G Drive?
    Posted by Ned Miller on January 18, 2016 at 9:27 pm
    I have many Lacie AC adapters for the silver vertical hard drives and can’t find my G drive adapter, a silver vertical full size unit.
    Is it safe to use the Lacie adapter? If someone has a full size, horizontal silver G drive could you please send me the voltage data on it’s AC adapter?
    Ned
    Ned Miller
    Chicago Videographer
    http://www.nedmiller.com
    www,bizvideo.com
    Bob Zelin replied 10 years, 8 months ago 2 Members · 3 Replies
  • Bob Zelin
    January 20, 2016 at 5:53 pm
    I went to google –
    the Lacie power supplies are 12 V power supply
    and look, here is the result of the google search on the
    G-Technology power supply –
    https://support.g-technology.com/kbase/users/kb.php?id=161&print=1
    so it’s 12 V also !
    so yes, it should work.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Ned Miller
    January 20, 2016 at 6:51 pm
    Thanks Bob. So the current doesn’t matter? I thought it was an inner pin thing and that could blow the supply. So you’re saying any of my Lacie 12v can do it, right?
    Ned
    Ned Miller
    www,bizvideo.com
  • Bob Zelin
    January 20, 2016 at 9:18 pm
    the power supply has a current rating. This means that the drive requires a certain amount of amps to operate. For example, you keep plugging in lamps, and a vacume cleaner into your wall outlet of 15 amps. After a certain point, the circuit breaker will blow, because it does not have enough amperage to power all the lamps, vacume cleaner (and air conditioner).
    Same with this – the drives take 12 V. I assume that the power supplies (you did not specify exact models) take 1.5 – 2 amps.
    If you have a G-Tech that takes 3 or 4 amps (I doubt it), then the power supply will get very hot to the touch, and eventually stop working. But I am guessing that these are all 1.5 to 2 amps, so you should have no issue.
    And when smoke starts to bellow out of your drive array, well, I really make sandwiches for a living and just stalk on Creative Cow.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
