Activity Forums Apple Final Cut Pro Legacy Can I use a full mix and M+E track to extract clean dialogue ?
  • Can I use a full mix and M+E track to extract clean dialogue ?
    Posted by Nick Meyers on August 1, 2020 at 8:31 am
    the topic says it all really:
    i have an old archived show with no dialogue stems.
    there are however 2 tracks of a full mix, and 2 more tracks of an M+E.
    would there be some clever phase trick to get just the dial and VO from the old film, clean of the old music ?
    i can live in hope ☺
    thanks in advance.
    nick
    Nick Meyers replied 6 years, 1 month ago 2 Members · 2 Replies
  • Michael Gissing
    August 3, 2020 at 12:17 am
    Phase might work to some degree if the two tracks are sample accurate and you can line up the files to be sample accurate. I can’t remember of FCP7 can do audio phase reverse. I seem to remember it was possible. It might work better to import the files into a DAW where you can move the file by the sample to get the line up.
    Next problem is the M&E will likely not dip where the narration & dialog are so you will have to work to replicate the level dips or the phase cancel won’t work.
  • Nick Meyers
    August 11, 2020 at 6:05 am
    thanks, Michael.
    the files aren’t phasing so i guess that means they are not sample-acuralty lined up.
    and achieving that is a bit beyond what i can do in FCP (and no – FCP doesn’t offer phase reversal)
    ill see if the sound team are interested in solving it.
    hope you are safe n sound down in Tassie
    cheers,
    nick
