Activity Forums Apple Final Cut Pro Legacy can I un-nest a sequence?
  • can I un-nest a sequence?
    Posted by Mark Barroso on June 12, 2009 at 6:35 pm
    The final version of my 74 minute film is a sequence I labeled Master Sequence. That sequence is made of about 8 nested sequences. Those 8 also have nested sequences in them. I know that if I just click on them they become “un-nested” and open up as the original sequence.
    But what I’m trying to do is export it as an OMF file for an audio mixer. I want to deliver all of the audio tracks. The second best thing would be to export a stereo mix of the dialogue and a stereo mix of the music (4 tracks). Is there an easy, i.e., proper way to do this?
    The third idea would be to have a sequence without any nesting. Is there a way to paste to a new timeline a sequence without it being nested?
    FCP 6.0.5 /
    OS 10.4.11 /
    Mac Pro 2×2.66 Ghz Dual Core/ 2G RAM
    External: FW800 G-tech 500 HD and G-Tech Quad 750GB
    playback deck: Pan dv2500
    Brandon Kalinowski replied 13 years, 10 months ago 5 Members · 5 Replies
  • Shane Ross
    June 12, 2009 at 6:58 pm
    Yes. Open the nest. highlight everything. Hit COPY (CMD C). Go back to the main sequence. Delete the nest. Put the playhead where the nest started, hit PASTE (CMD-V).
    Nesting in nests…ugh. I hate nesting. Complicates things…case in point, you. YOu will have to open the nests and copy and paste your way out of it.
    Shane
  • Walter Biscardi
    June 12, 2009 at 7:06 pm
    [Shane Ross] “YOu will have to open the nests and copy and paste your way out of it. “
    Yep….
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Mark Barroso
    June 12, 2009 at 7:11 pm
    Thanks, guys. Sounds like a jail break.
    FCP 6.0.5 /
    OS 10.4.11 /
  • Taylor Whitney
    March 3, 2011 at 7:45 pm
    Nice photo!
  • Brandon Kalinowski
    October 21, 2012 at 11:35 pm
    I’m surprised no one knows this but if you can drag it from either the viewer or the browser, simply hold the COMMAND key before dropping it and it will expand.
