Activity › Forums › Adobe Photoshop › Can I select ‘Don’t Save’ for multiple files when closing?
  • Can I select ‘Don’t Save’ for multiple files when closing?
    Posted by Clay Stanton on June 18, 2010 at 10:36 am
    Hi –
    If I have worked on say 20 files, and then I select ‘Close All,’ Photoshop asks me if I want to save each individual file.
    Is there a way of choosing ‘Save’ or ‘Don’t Save’ for all the files without having to click it for each one?
    David Cabestany replied 16 years, 1 month ago 4 Members · 11 Replies
  • 11 Replies
  • Christina Rodriguez
    June 19, 2010 at 12:17 am
    Easy, just make an Action.
    Go to WIndows>Actions
    In the Action Window (btw: make sure button mode is NOT selected)
    Click the Little folder at the bottom. This will create a new action set (so it doesn’t get mixed up with the rest of the actions) Name it something like My Actions or Bob’s Actions (Bob being your name)…
    Then select the little paper button next to the folder. This is where you will actually start to make a new action.
    Name it “CLOSE-Don’t Save”
    Then close one of your pictures and don’t save it. (make sure you did something to it before starting the action, that way it asks you if you want to save and you hit NO.)
    Then stop the Action.
    Now, go to File>Automate>Batch
    Select your action (it should show the one you just made)
    Make sure you select “opened Files”.
    Click Ok and Viola.
    Then make a Save ALL action with the same process.
    I also have a rotate left or right action I make so I don’t have to use the menu,
    C.R.
  • Clay Stanton
    July 1, 2010 at 11:29 pm
    Christina – thank you! I use Actions a lot.. and when I asked the question it was actually to solve the problem of how to close a bunch of files that were left open after I ran a particular Action!!
    I never thought to add a Close and Don’t Save Action! Just did it and everything is great now, so thanks again 🙂
    July 2, 2010 at 6:40 pm
    Glad it helped!
    C.R.
  • Richard Harrington
    July 4, 2010 at 8:29 pm
    Just option or alt click first dialog box to apply to all
    Richard M. Harrington, PMP
    Author: Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
  • David Cabestany
    August 17, 2010 at 11:25 pm
    Richard, that method does nothing, I tried it with Photoshop and illustrator, i used alt, command, ctrl and then several combinations of this keys and in every case it asked me individually to save each file.
    Perhaps it’s a windows only thing?
    August 17, 2010 at 11:32 pm
    Just option key and click don’t save works fine
    Author: From Still to Motion, Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and Motion Graphics with Adobe Creative Suite 5 Studio Techniques
  • David Cabestany
    August 18, 2010 at 12:44 am
    No, it doesn’t.
    August 18, 2010 at 2:22 pm
    File > Close All
    On Older Photoshops (Option/Alt) click No when asked to save changes
    On Newer versions, check the Apply to All box in save dialog
  • David Cabestany
    August 18, 2010 at 3:40 pm
    Richard are you on a pc or a mac? I have a mac with cs4 installed and neither option is viable, in fact there’s no “Apply to all” checkbox available. This has to be a windows only thing, I have been working with photoshop for 15 years on mac and never saw those options you mention, unless it was recently included in cs5 that option is simply not there.
    August 19, 2010 at 5:24 pm
    Mac
    The Apply to all option is in CS5 (not sure if earlier)
    The Option shortcut works on CS3
