Activity Forums Apple Final Cut Pro Can i save animated 4 x solid/text layers into single effects preset?
  • Can i save animated 4 x solid/text layers into single effects preset?
    Posted by Luke Watson on June 6, 2017 at 3:36 pm
    I have a lower third consisting of 2 x custom color blocks (cropped) and 2 x text layers,
    all animated using slide transitions to slide onto screen, and fade out transitions at the end,
    is it possible to save this whole set as a single pre-set effect?
    Or do i have to rebuild in Motion and save into FCPX that way?
    Luke
    Luke Watson replied 8 years, 11 months ago 2 Members · 2 Replies
  • Andy Neil
    June 6, 2017 at 5:13 pm
    You need Motion to build this effect and save it as a lower third title in your title browser. It’s worth having Motion if you like to make custom gfx like this for your projects.
    Andy
    https://plus.google.com/u/0/107277729326633563425/videos
  • Luke Watson
    June 6, 2017 at 6:39 pm
    Thanks -was hoping I could do this within FCPX but no worries, I’ll build and export from Motion
