Activity › Forums › Adobe After Effects › can i run both gridiron x-factor AND nucleo?
Steve Forde replied 20 years, 2 months ago 2 Members · 12 Replies
Scott G
June 12, 2006 at 4:07 amanother issue i’m coming up against is when i try to use nucleo to do a ram preview. the popup message comes up, then it starts rendering. the “est remain” starts counting down…
then, a short way into the rendering process, the entire screen starts flickering madly. i can just make out in the flickering that the counter is still counting down, till it gets to “est remain: 1sec”. then it stays on 1 sec for about 15 seconds. then then flickering stops, and the “est remain” jumps back from 1sec to 40 secs, or something else, and rendering continues from where the flickering started.also, once the ram preview is complete, the popup message windows seem to stop playback when they popup (just like switching out of afx would stop playback).
these two things are incredibly annoying. is there anything i can do about this?
also, nucleo feels the need to tell me continually that i have other applications running. of course i have other apps running! i’m trying to design here! is there any way to turn off this annoying popup?
Steve Forde
June 14, 2006 at 5:11 pmWould it be possible for you to send us the .aep? (no footage needed at this point – will ping if we need it).
Please send us the project at: support@gridironsoftware.com
In terms of other apps running, Nucleo is designed to basically max out a machine to provide fast previews and renders. I really recommend not running anything beyond AE and Nucleo.
Nucleo Pro is the version you want with multiple applications running, and not having Nucleo max everything out.
check out https://www.gridironsoftware.com/NucleoPro
Steve
GridIron Software Inc.
