Activity › Forums › Apple Final Cut Pro › Can I rename clips on the root level?
  • Can I rename clips on the root level?
    Posted by Noam Osband on January 20, 2018 at 6:35 pm
    I have some imported clips in FCP X. I want to rename them but I want the renaming to also impact them at the root level (in the original media folder). Is there a way to do that? I’ve looked online and haven’t seen anything. There must be a way to do it as opposed to renaming in the program and then going to the file and renaming it in Finder. Anyone have a clue?
    Bret Williams replied 8 years, 8 months ago 3 Members · 2 Replies
  • Jeff Kirkland
    January 20, 2018 at 10:12 pm
    Not that I know of. It’s just a part of the workflow that you need to rename the files before import.
    Renaming the files at the finder level is always going to mean having to re-import into FCPX as the renaming you do inside the app is virtual – so if you bring in a file from the finder called ClipA and rename it in X to MyClip, FCPX is still connecting that to a file in the finder called ClipA. If you rename it in the finder to MyClip, FCPX will still be looking for ClipA in the finder and you’ll have a missing file, with no way to relink it other than to re-import.
    I guess there’s a possibility that an app may may exist to do that via XML but I personally would be very upset if I renamed a file inside FCPX and it changed them in the finder too – any media shared across multiple libraries would suddenly become unlinked and it’d be a nightmare.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Bret Williams
    January 21, 2018 at 4:22 pm
    It’s just another one of those “could do it in legacy” things.
    _______________________________________________________________________
    https://BretFX.com FCPX Plugins & Templates for Editors & Motion Graphics Artists
    Hang Tag https://bretfx.com/product/hang-tag
    Overshoot Text https://bretfx.com/product/overshoot-text/
    Outliner https://bretfx.com/product/outliner/
    Clock Maker https://bretfx.com/product/bretfx-clock-maker/
