Activity Forums VEGAS Pro Can I make voices have a higher pitch?
  • Can I make voices have a higher pitch?
    Posted by Amberle on May 18, 2007 at 9:01 pm
    My teacher is giving me the weekend to figure this all out now. Thanks for the help 😀 …I’m just not a computer person. It did make the video and audio move faster, but it didn’t make the voices more high pitched like it did when I used the scrubbing tool. I’m sorry that this problem is STILL dragging on, but I would like to know if there is a way to make the voices have a higher pitch?
    Doug Graham replied 19 years, 3 months ago 5 Members · 5 Replies
  • Gary Kleiner
    May 18, 2007 at 9:28 pm
    You can easily control pitch by selecting your audio on the timeline and hitting the + and – keys just to the left of your backspace key.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Terry Esslinger
    May 18, 2007 at 9:49 pm
    I believe there is a setting in preferences that allows you to make speed changes without changing the pitch. I think if you uncheck that you might get it done.
  • Steven J casey
    May 19, 2007 at 4:53 am
    Try the audio plugin “pitch shift”. On the left of your screen, in the track header, click the green icon to bring up the track effects window. Click the same green icon in the new window (upper right). Find “pitch shift” and click Add, the click OK. Now you’ll get an effects control window. Easiest thing to do from here is use the drop down box and select either “fifth up” or “third up”. Try them both to see which you like. Once you’ve decided, click the red X in upper right to close that window.
    steven
  • Doug Graham
    May 20, 2007 at 2:13 pm
    Amberle,
    Please see my reply to your earlier thread.
    It would make it easier to help you if you stopped creating a new topic every time, and simply replied to people in an ongoing thread if you have more questions.
    Regards,
    Doug Graham
  • Doug Graham
    May 23, 2007 at 11:19 pm
    Sheesh. Twenty “help me!” posts and not one follow-up or word of thanks.
    Regards,
    Doug Graham
