Activity › Forums › Adobe Premiere Pro › Can I install Premiere 6 & CS3
Posted by Ted Strickler on February 9, 2009 at 12:01 amCan I have Premiere CS3 and Premiere 6 installed on the same computer and only use one at a time?
In other words, I would only run one or the other. I want to see if I get a sound waveform in 6.Ted Strickler replied 17 years, 6 months ago 2 Members · 2 Replies -
Chris Buttacoli
February 9, 2009 at 2:54 amI have 6.5 and CS3 both installed, with no problems. What do you mean waveform??
6.5 shows a waveform when zoomed in 2 sec mode or closer, CS3 shows it in every zoom level…. however….. cs3 does not amplify the waveform display if you have a recording with low audio levels – where 6.5 does.
One way around this is to normalize the audio on the timeline by right clicking the audio track and selecting audio gain, and then pressing the normalize button. This will actually boost the audio levels up to 0 db.
Of course, make sure your audio track is twirled down, otherwise you won’t see the waveform at all. And if you do need it bigger, you can always expand the height of the track and the waveform will increase in size.
Ted Strickler
February 9, 2009 at 3:14 amWhat I mean by waveform is my audio waveform does not show in the timeline or the preview window. I have a thread going on that one.
The reason for this post is because I wanted to install my older Premiere 6.0 and see if there is an audio waveform with that version. I am just throwing darts trying to figure something out but I didn’t want to cause a conflict between 6.0 and CS3. You have answered that for me and I thank you very much.
Strange thing is that mp3 audio shows up just fine.Ted
