Activity Forums Boris FX can I install fx9 & graffiti5 on V8,9or 10?
  • can I install fx9 & graffiti5 on V8,9or 10?
    Posted by Bob Tyson on March 15, 2011 at 4:30 am
    Aloha Gang, just located or actually looked for my install disks and installer only goes to V7. I’m on W7 with V8,9 +10 installed. do I need To buy an upgrade or?? Thanks for your time …bobt
    John Rofrano replied 15 years, 6 months ago 3 Members · 5 Replies
  • Peter Mcauley
    March 15, 2011 at 11:56 am
    I believe you should be able to install and run FX 9 and Graffiti 5 in Vegas 8, 9 and 10, however, for Vegas 10 you’ll have to use the 32 bit version as neither FX nor Graffiti currently offer support for 64 bit hosts. We’re working on 64 bit host support and expect to have that available very soon but it’s 32 bit only at the present time.
    Cheers,
    Peter.
  • John Rofrano
    March 15, 2011 at 2:42 pm
    [bob tyson] ” just located or actually looked for my install disks and installer only goes to V7″
    Don’t forget to download the latest Trial version. The installer will work with all versions of Vegas and you can unlock it with your existing license.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Bob Tyson
    March 16, 2011 at 1:59 am
    aloha Gang , tried to install trial version and would not go next after name,co,#. This # may only be a s/n and not a license that was in the paperwork with cd,s. This is on a W7pro64bit machine..Thanks for your time…bobt..
  • Peter Mcauley
    March 16, 2011 at 2:06 am
    Not a problem … at this stage I’d like to suggest that you send an email to our support gurus (support@borisfx.com) and one of them will sort it out for you. And feel free to cc me on that message (peterm@borisfx.com) to make sure that it gets through.
    Cheers,
    Peter.
  • John Rofrano
    March 16, 2011 at 2:24 am
    [bob tyson] ” tried to install trial version and would not go next after name,co,#. This # may only be a s/n and not a license that was in the paperwork with cd,s.”
    Actually, this only works with the trial serial number that you should have gotten in an email after you registered to download the trial. It will not work with your “real” license key. So check your email spam folders and make sure you use the trial key.
    ~jr
