Activity Forums VEGAS Pro Can I increase the program font size in Sony Vegas Pro 9
  • Can I increase the program font size in Sony Vegas Pro 9
    Posted by Tim Riordan on September 22, 2012 at 1:35 pm
    I’m wondering if it is possible to increase the program font size in Vegas Pro 9, without increasing all font sizes in Windows 7. I use two monitors – one 22″ for preview which is fine, but the other is only 16″ (on my laptop), which I use for the editing. That is a bit small and I’m having difficulty reading the fonts. Is it possible to do this? Thanks
    Tim
    “There are three kinds of people in this world: those who can count and those who can’t”
    Menahem Khasin replied 6 years, 10 months ago 3 Members · 2 Replies
  • John Rofrano
    September 22, 2012 at 7:22 pm
    [Tim Riordan] ” but the other is only 16″ (on my laptop), which I use for the editing. That is a bit small and I’m having difficulty reading the fonts. Is it possible to do this? “
    No. Vegas Pro uses your Windows fonts so you would have to change all of Windows. Changing the Windows font sizes has always caused problems with text being cut off so I would not recommend it. You be better to run that laptop at a lower resolution if you’re having trouble seen the screen.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Menahem Khasin
    November 13, 2019 at 6:34 pm
    [USING SONY VEGAS 12.0 PRO]
    Of course you can: through the shortcut on your desktop or start> right click> open file location.
    Then, right click> properties> “compatibility” tab> “run compatibility troubleshooter”.
    Use the troubleshooter to adjust the programm to high scale d.p.i.
    there are two types of people: those who can extrapolate from incomplete data.
