Activity Forums Adobe Photoshop Can I import Camera Raw settings?
  • Can I import Camera Raw settings?
    Posted by Matteo Badin on August 8, 2018 at 10:30 am
    Hi everyone, Camera Raw automatically saves the settings in a .xmp file located in the folder where my RAW photos are. I was wondering if these settings can be imported in other RAW files (in order to save time while post-producing my photos) and how I could do it. Thanks!
    Matteo Badin replied 8 years, 1 month ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    August 8, 2018 at 4:50 pm
    I believe this article will answer your question quite thoroughly:
    https://www.peachpit.com/articles/article.aspx?p=2111972&seqNum=18
    In brief, you can save and load RAW settings in Photoshop. Using Bridge you can process multiple photos with the same settings on open. More details in article.
    There is also the quick option to “use previous correction” in the Photoshop open RAW dialog if you know you want to apply the same correction to just a few files without saving the settings.
    Senior Graphic Designer
  • Matteo Badin
    August 8, 2018 at 5:45 pm
    Great! Thank you very much!
