Activity › Forums › Adobe Premiere Pro › Can I import a Premiere CS3 Project into Premier CS5?
  • Scott Jolley
    May 10, 2010 at 6:33 pm
    It turns out because I was in a trial version, Premier could not update. The full license took care of that little issue.
  • Paul Del vecchio
    May 10, 2010 at 6:35 pm
    You can open the CS3 project file in CS5, and it will create a copy and save it in the new CS5 format. It won’t touch your original CS3 copy. From there, you can make changes in CS5.
    Paul Del Vecchio – Director
    https://www.triple-e-productions.net
    https://www.pauldv.net
