Activity Forums Adobe After Effects can i import a path without it becoming a mask?
  • can i import a path without it becoming a mask?
    Posted by David Lieberman on February 15, 2008 at 11:51 pm
    Hello,
    I’ve seen a tutorial on creative cow on how to import paths and motion paths. the result was that it imported a mask in the paths shape. but is there any way to actually import a work path from photoshop which is close (as a closed circle maybe) without it becoming a mask? I dont need the fill i simply want the lines to use trapcode 3d stroke with.
    The only solution i found so far was to auto trace every mask i import…
    Thanks for the help.
    dave
    thanx for the help.
    David Lieberman replied 18 years, 6 months ago 2 Members · 2 Replies
  • Chris Heuer
    February 16, 2008 at 2:21 am
    After the mask is applied to a layer, hit MM on your keyboard to open the mask properties and change the drop down menu from “Add” to “None”. Now you have a path!
    You can also skip Photoshop and use the pen tool (or the Rectangle/Circle tool) and create open or closed masks right in AE, (you will still have to change closed shapes to “None”) that’s how I create paths for 3D stroke.
    P.S. If you create paths in AE, create a New Solid and apply the paths to it, that way your footage won’t be effected.
    Hope this helps (and that I wasn’t telling you a bunch of junk you already know!)
    C
    Chris Heuer
    Freefall FX, LLC
  • David Lieberman
    February 16, 2008 at 7:49 am
    i feel like a grade A moron for not noticing the NONE option myself…
    thank you.
    thanx for the help.
