Activity Forums Adobe After Effects Expressions Can i get a “figed time”?
  • Can i get a “figed time”?
    Posted by Fabrice Boulard on February 12, 2018 at 4:06 pm
    Hi everybody!
    I did a metronome. The vertical bar is animated by a simple expression :
    var amplitude = 32;
    var bpm = 120; (beatPerMinute)
    var f = (bpm/60)*2; (frequence)
    sin(2*Math.PI*f*time)
    Now i want to play a sound at the right time. It’s why i created a comp. Into this, a only one soundlayer with a marker at the frame number 1 (not 0).
    I commented this marker : “playSound”.
    I addded this comp in another comp to time remaptime it and add expression on it :
    var c = thisLayer.source;
    var myComment = "playSound";
    var m= c.marker.key(myComment);
    var amplitude = 32;
    var bpm = comp('metronome').layer('barre').effect("Paramètre glissière")("Curseur");
    var velocité = 2*Math.PI*((bpm/60)/2);
    var v = amplitude*Math.sin(velocité * time);
    frames = timeToFrames(t = time + thisComp.displayStartTime, fps = 1.0 / thisComp.frameDuration, isDuration = false);
    iTime = framesToTime(frames+1, fps = 1.0 / thisComp.frameDuration);
    iV = amplitude*Math.sin(velocité * iTime);
    absV = Math.abs(v);
    absiV = Math.abs(iV);
    if(absV == amplitude || (absV
    I need to substract the time value when the condition begins true and i don't know how to do that...
    "m.time + time - figedTime"
    Thx for help
    Fabrice Boulard replied 8 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
