Activity Forums Adobe After Effects Can I frame blend between two video tracks?
  • Can I frame blend between two video tracks?
    Posted by Sam Hakes on February 20, 2014 at 8:28 pm
    I’m working on a green screen project where the talent has a long pause between sentences. I cut out the pause and put the tracks up next to each other. On playback there is a subtle jump cut between them. I’m wondering if there is a way After Effects can create a frame that would go between the two clips like the frame blend function does for footage in one track? Any suggestions?
    Thanks, Sam
    Running AE CC & OSX 10.9
    Sam Hakes replied 12 years, 7 months ago 2 Members · 2 Replies
  • Todd Kopriva
    February 20, 2014 at 9:55 pm
    You can use the Timewarp effect for this.
    This handy and inexpensive script automates the work:
    https://aescripts.com/pt_framerestorer/
    After Effects team blog
  • Sam Hakes
    February 21, 2014 at 3:34 pm
    Thanks Todd! The Frame Restorer plugin worked for me. I first tried exporting the two keyed tracks as a Photoshop sequence but Frame Restorer had a problem with the alpha channel:
    So I exported the clip with everything composted, deleted one frame between the two clips and told the Frame Restorer to “Restore Missing Frames” and it worked! I don’t think anyone will notice I cut out a pause in his talking now. Thanks!
