Activity Forums Adobe Premiere Pro Can I export my PNG subtitle layer that was burnt in to a sidecar file or timed transcript?
  • Can I export my PNG subtitle layer that was burnt in to a sidecar file or timed transcript?
    Posted by Ashley Davis on March 10, 2016 at 9:31 am
    A client asked for subtitles for a video I’m working on. They made it seem like they wanted them burnt in so I created the text in InDesign on separate sheets and imported them all into Premiere as PNG files and moved them on to the timeline to the right areas. They have now stated they want them separately so they can be toggled on or off. Is there anyway I can simply use the layer I’ve already done for this or do I have to start from scratch? They’ve stated they want it as a sidecar file or timed transcript
    Ashley Davis replied 10 years, 6 months ago 3 Members · 3 Replies
  • Tero Ahlfors
    March 10, 2016 at 11:10 am
    Nope: https://helpx.adobe.com/premiere-pro/using/closed-captioning.html
    If you’re on Windows you could use the free Subtitle Edit software to remake your subs and export them in pretty much every kind of format available.
  • Andreas Kiel
    March 10, 2016 at 10:50 pm
    Ashley,
    It depends where the subtitles should be used. For DVD or BluRay export an EDL for subtiles.
    Import into Excel in clean up the times there till you have only tc in tc out and the subtitle file name in each row. Then add a prefix like _#_ to each to each subtitle file name.
    Create a new folder and export the Excel file as comma separated list into this folder. Copy the pngs into the same folder. Open the list in a text editor and add a line before the first line: $SetFilePathToken = _#_
    Your STL for DVDs is ready. Apple DVDSP
    Some more info here:
    https://documentation.apple.com/en/dvdstudiopro/usermanual/index.html#chapter=19%26section=13%26tasks=true
    For Adobe Encore it is a similar procedure.
    You can use the timing also to create SRTs for YouTube, Vimeo etc.
    If you need some more help drop me an email : kiel at spherico dot com
    – Andreas
    Spherico
    https://www.spherico.com/filmtools
    “He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil
  • Ashley Davis
    March 11, 2016 at 8:48 am
    Not for DVD. They just want it for online, probably YouTube
