Can I export clips seperately?
I have a timeline with 24 greenscreen shots that i have edited, and now need to get into After Effects for keying and compositing. I have tried to import the Premier sequence into After Effects but it then comes up as one single clip, which is not what i need.
Is there a way to export the whole sequence as seperate clips without manually going through every single clip and exporting it seperately? Hopefully there is a workaround because i have 3 or 4 shots where 24 smaller clips are going to be composited into each shot seperately.
Please help!
Cheers
