Activity Forums Apple Final Cut Pro Can I erase my FCPX 10.1.1 Library & Events and Start Over Clean?
  • Can I erase my FCPX 10.1.1 Library & Events and Start Over Clean?
    Posted by Ned Miller on March 23, 2014 at 10:40 pm
    I have just started with X and downloaded some exercise files from the Lynda tutorial site and had some Projects & Events from when I was using the previous version. Now it’s a mess and I would like to just erase them all and start over. Is that OK? Will X start clean a new Library? I am on OS 10.9.2 if that matters.
    Thanks for your advice
    Ned Miller
    Chicago Videographer
    http://www.nedmiller.com
    www,bizvideo.com
    Bret Williams replied 12 years, 5 months ago 3 Members · 2 Replies
  • Nikolas Bäurle
    March 23, 2014 at 10:58 pm
    10.1.1 will ignore your old projects and events. Once you open it will create a library with an empty event inside. You can then update your old events and projects, X will look for the old folder structure and create a library with an event containing your updated projects, and all the updated events.
    Of course, if you don’t want your old practice events an projects you can erase them, X won’t read them anyway unless you tell it to update.
    “Always look on the bright side of life” – Monty Python
  • Bret Williams
    March 24, 2014 at 12:02 am
    And of course you don’t want just “A” library. If you work like most, you want a library for each job you do. And I use the word job of course because FCPX hijacked the word project.
