Activity Forums Adobe After Effects Can I edit sound?
  • Can I edit sound?
    Posted by Miriam Millan on October 8, 2005 at 5:14 pm
    Thanks for responding. Can people actually edit with sound tracks in After Effects? I can hear the sound only when I hit the period on the numberpad.
    Is there a way to be able to edit the sound while working on the animation, or can you edit sound only when you import the piece into final cut pro, etc.
    Thanks again,
    Miriam
    Thehardmenpath replied 20 years, 10 months ago 3 Members · 2 Replies
  • Ben G unguren
    October 8, 2005 at 9:01 pm
    You can, but generally you don’t. AE does not work in real time. To edit sound, you need to work in real time. So when you press the period key on the numeric keypad, it “previews” the audio in real time. When you RAM Preview, it will play the sound in real time (because it is playing the video real time). Otherwise, AE takes as long as necessary to create each frame. Sometimes it can do this real time (for really simple), usually not. So it doesn’t even try to play audio while you work.
    I believe most people match sound up with their animations in an editing program like Final Cut Pro or an audio program such as ProTools. That’s how I do it, at any rate.
    ben
  • Thehardmenpath
    October 9, 2005 at 9:36 am
    When you press the control key while choosing a keyframe in the timeline, you hear the audio at that frame just like in Premiere without pressing anything. That helps with some small adjustments, but I agree AE is not the best choice for editing audio.
