Activity Forums Apple Final Cut Pro Legacy Can I edit FlipCam into my P2 documentary?
  • Can I edit FlipCam into my P2 documentary?
    Posted by Ben Adler on April 3, 2009 at 3:16 pm
    I am making a documentary shooting dvcprohd 720p and I would love to incorporate some footage that I will shoot with the Flip Mino HD.
    I have done a test and I cant play it in the same timeline as my p2 footage. It looks like it is rendered – it just won’t play. I am thinking this might be because it is 30fps as oppose to 25? (PAL land)
    Does anyone know a way around this and how I can work these two formats together.
    Many thanks,
    Ben
    John Fishback
    replied 17 years, 5 months ago
    4 Members · 6 Replies
  • Tom Wolsky
    April 3, 2009 at 3:19 pm
    Just won’t play like how just won’t play. The playhead doesn’t move? The screen is unrendered? The screen is black? White? Green? Did you convert the media into an FCP useable format?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Ben Adler
    April 3, 2009 at 3:51 pm
    The audio continues but the image freezes. Also forgot to mention that the flipcam shoots mpeg4. So it is an mpeg4 30 fps image.
    It works fine in its own sequence but in the 720p 50fps sequence the render bar is orange, which Ive never seen, so It doesn’t need rendering but just freezes although the audio continues.
  • Walter Biscardi
    April 3, 2009 at 3:58 pm
    You need to convert that footage to a more edit friendly codec. Compressor might be able to this.
    When we get into situations like this, we simply take whatever video feed comes out of the camera and feed it through our Kona 3 to capture / convert the footage to what we need during ingest. We’re actually about to do this with a JVC HD consumer disk-only camera that only has HDMI as it’s HD output.
    I’m picking up the AJA HA5 convert to convert that signal to HD-SDI and we’ll just capture it in as 720/60 ProRes to match the rest of the footage.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Tom Wolsky
    April 3, 2009 at 4:26 pm
    Orange means you’re in Unlimited RT and that the file will play back with dropped frames. Orange does not mean it does not need to be rendered. Read the manual sction on rendering and color displays in the timeline. You can either render and keep rendering or you can do as Walter says convert this media into something that approximates a video format, which these cameras most certainly do not shoot.
    All the best,
    Tom
  • Ben Adler
    April 3, 2009 at 5:24 pm
    Thanks a lot Tom and Walter.
    Another question I have on dropped frames, since you mention it is:
    Will increasing the RAM in my computer decrease the likelyhood of dropped frames. My computer has 2gb RAM and generally runs fine – except I occasionally get dropped frames in fcp whatever my settings are at.
  • John Fishback
    April 3, 2009 at 5:30 pm
    Usually, dropped frames are an indication of a slow drive.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
