Activity Forums Apple Final Cut Pro Legacy Can I drop frames during digitizing to create time lapse?
  • Can I drop frames during digitizing to create time lapse?
    Posted by Justin Toops on February 6, 2008 at 2:52 pm
    A producer wants to capture 8 hours of time lapse footage on DVCPROHD, and then shrink it down in post for a 30 second commercial. He does not want to do the time lapse in camera (the easy way…) because he believes it will limit the options of the footage later. An early test where we digitized 20 min of DVCPRO footage and used varible speed (@ 14,000 %) to shrink it to 2 seconds in the timeline was more than our Intel Mac could handle… and it could not play the two seconds in real time without shuddering, pausing and finally quitting.
    My question: If he shoots this footage in real time, and wants to do a timelapse, can I change my digitizing settings, for example, to capture 1 frame for every minute of video for 29.97 playback?
    Josh
    Editor/Chess Player, Washington DC
    2×3 GHz Intel Mac, 4 gigs RAM
    FCP 6, DVDSP4, Motion3
    KONA 3 capture
    Jeremy Garchow replied 18 years, 7 months ago 7 Members · 9 Replies
  • 9 Replies
  • Emma Mcneill
    February 6, 2008 at 4:13 pm
    No you can’t, and time lapse that isn’t done in camera isn’t time lapse as you have just pointed out so this sentence has served as nothing more than positive re-enforcement for your own position on this situation!
    ;o)
    Emma
  • Mark Raudonis
    February 6, 2008 at 4:39 pm
    When trying to do this drastic of a time lapse, you should create a separate QT movie. That should play just fine.
    Mark
  • David Bogie
    February 6, 2008 at 4:49 pm
    Here is my usual list links for timelapse questions.
    Your producer has only a vague idea of what he wants and no idea what the best way to do it could be. The BEST way to do the most flexible and beautifully elegant timelapse is to shoot competent stills.
    https://visibleearth.nasa.gov/view_set.php?categoryID=2363
    https://www.kenstone.net/fcp_homepage/time_lapse_article/time_lapse.html
    https://www.gethincoles.com/
    https://www.creativepro.com/story/howto/24670.html
    https://www.haworth-village.org.uk/nature/time-lapse/thumbs.asp
    https://www.macworld.com/weblogs/macosxhints/2006/07/timelapsemov/index.php
    https://digitalmedia.oreilly.com/2005/05/18/timelapse.html
    https://www.timelapsedigital.com/
    bogiesan
  • Tom Matthies
    February 6, 2008 at 5:15 pm
    Sony’s XDCam HD has a time lapse feature built into it. Might be worth a try looking at it to see if it will do what you want.
    My 2¢ worth.
    Tom
  • Bret Williams
    February 6, 2008 at 6:01 pm
    EditDV used to have this exact feature. Capture every _th frame. But of course that was back in 1998 on a 604e processor. I’m sure we can’t expect anything today to have this functionality today. 🙂
    EditDV morphed into something else after a few years. I’m sure that app probably still has the function. Of course, you realize that it would still be an 8 hour capture. And then if you don’t like the result, it would be another 8 hour capture. So, how does this give you more options in post? If you have the drive space, capture the 8 hours and run tests on small portions to see if you like the look by doing a speed change.
  • Jeremy Garchow
    February 6, 2008 at 6:48 pm
    First of all, if you render the 14,000% speed change, it should work. Second of all if you set up an interval record, check out Nattress big Box o Tricks in which he has a interval record feature that assembles the frames together for a smoother time lapse.
    https://www.nattress.com/Products/BigBox/TimeTools/GTimeLapse.htm
  • David Bogie
    February 6, 2008 at 7:04 pm
    Let’s start over:
    Time lapse of what, exactly?
    What’s the end result supposed to be, exactly?
    The techniques required to accomplish any particular time compression assignment are dependent upon budget, desired results, time for the even to occur, and time compression factor. Shooting stills, using a still camera or the still feature on a video camera, provides radically different results than shooting video. But the results may not be what the client is expecting.
    You’ll do some tests, yes?
    bogiesan
  • Justin Toops
    February 6, 2008 at 8:53 pm
    [david bogie] “Let’s start over:
    What’s the end result supposed to be, exactly? “
    The spot is one where a woman is assembling something in a completely empty room. She is building a rather complicated piece, so while we see 8 hours of time lapse footage in 30 seconds we’ll watch her dart all over the place while this object is formed.
    For the idea, as nuts and uncreative as it is now, the plug in from Nattress that was suggested seems to fit our need. (thanks Jeremy) I made a sample of it for the producer… hopefully it will persuade him to take an alternative technique for the spot.
    Can anyone explain this: even rendered in the timeline, a 8 min dvcprohd clip set to play at 14,000% speed (resulting in a 5 second clip) would stumble, stop, and quit. Is that because the processor isn’t able to handle the amount of data in the HD?
    Justin
    KONA 3 capture
  • Jeremy Garchow
    February 6, 2008 at 9:07 pm
    Are you sure it’s rendered and not just at Full rt? Go to your Sequence > Render Selection and Sequence > Render All menus and make sure every option is checked, including ‘full’. Then hit option-r to render all.
    If that doesn’t work, have you tried exporting it as a self contained Quicktime and reimporting?
    Jeremy
