Activity Forums Adobe After Effects Can I create ‘hand held’ camera effect using Motion Tracker?
  • Can I create ‘hand held’ camera effect using Motion Tracker?
    Posted by Movie Maker on January 1, 2007 at 4:48 pm
    Hi, I am trying to create an illusion that requres the camera to be mounted on a tripod while filming. I also want the finished clip to look like it was filmed on hand held camera.
    If I shoot a black dot on a white card using a hand held camera and then use the motion tracker to follow the black dot, can I transfer the pattern to the tripod shot footage?
    It sound like it should be easy but I’m not sure where to start. I realise I will have to zoom into the tripod shot footage in order to fill the edges of the screen as the hand held effect will move it.
    Many thanks
    Jimmy
    Movie Maker replied 19 years, 8 months ago 3 Members · 4 Replies
  • Chris Smith
    January 1, 2007 at 5:43 pm
    Yeah, I do it all the time. But I found a good wiggle expression with motion blur turned on can do the look really well without the need to track a real dot.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Alexander Gao
    January 1, 2007 at 6:34 pm
    If you drag your entire composition into a new one, and then for the position of the comp, enter the wiggle expression which is like this:
    wiggle(*,**)
    *the number of pixels you want the “wiggle” to encompass
    **the number of times/second the distance will be changed
    I’m sorry if you already know this, but I picked it up from Aharon Rabinowitz’s tutorial, and I think it could help those who don’t know it.
    Alexander Gao
    “When the revolution happens, I’ll be leading it.”
  • Movie Maker
    January 1, 2007 at 7:56 pm
    Many thanks, it sounds a good option, I’ll have a play.
    Happy New Year
    Jimmy
  • Movie Maker
    January 1, 2007 at 7:59 pm
    Hi, the previous post suggested similar so I will give it a try.
    Happy New Year
    Jimmy
