Activity › Forums › Adobe Premiere Pro › Can I convert an Open Captions Stream to Closed Captions?
  • Can I convert an Open Captions Stream to Closed Captions?
    Posted by Mike Kann on January 30, 2018 at 4:04 am
    I have created an Open Captions Stream in Premiere Pro CC 2018 with the intention of burning it in. Client has now changed their mind and wants to be able to turn it on or off.
    Is there anyway to convert my Open Captions Stream to a Closed Captions Stream? The Export>Captions option is not available (I assume because they are open captions) nor is the sidecar option available in the export menu. I also can’t seem to find a way to copy paste all the captions from the open stream to a closed stream.
    Any ideas?
    Thanks for any help
    -Mike
    Joshua Jackson replied 7 years, 8 months ago 6 Members · 5 Replies
  • Trevor Asquerthian
    January 30, 2018 at 9:10 am
    You should be able to export the captions – maybe sub sequence just that track?
    I’ve not had much joy exporting and importing either open or closed captions. They both come in with a resolution of 720×480. The closed caption file has a frame rate of 29.97. The open caption does not seem to offer an option to wrap the text and the closed captions come in with very strange formatting / letter spacing.
  • Bouke Vahl
    January 30, 2018 at 9:18 am
    Closed captions are only metadata about text, color, position and timing.
    They have NOTHING to do with subtitles, and must obey a different set of rules.
    If you need closed captions, do read a lot about it, and then you probably decide you want to outsource.
    Bouke
    http://www.videotoolshed.com
  • Andreas Kiel
    February 1, 2018 at 6:27 pm
    In Browser select the caption stream and then go to File -> Export -> Captions.
    As format I would use .srt.
    If you need broadcast CC follow Bouke’s advice.
    For Web you can use the SRT.
    Spherico
    https://www.spherico.com/filmtools
    \”He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil
  • Michael Sacci
    February 1, 2018 at 8:03 pm
    I do a lot of closed caption fixing as part of me job and I don’t see a clear path from Premiere’s internal caption tool.
    One issue is there is a lot of formatting with Open Captions that will not transfer to other standards. With closed captions all you can do is set the color and placement of the text. (Adobe’s Open Subtitles works the same way).
    You can Export Open Caption clip from the bin into srt and xml. I did a test and the srt will not import into MacCaption, which is the program that I do a lot of conversion with. I can bring in the xml but the placement is not correct.
    What needs to be remembered is that every different playback and delivery method needs a different type of file. DVD, BluRay, youtube, web players and what not need different files.
  • Joshua Jackson
    January 17, 2019 at 3:54 pm
    I usually copy the caption file in the project box and then “Modify > Captions” to the proper caption type. But this might only work one way (from 608/708 captions -> Open Captions), which is usually the only direction I go in.
