Activity › Forums › Apple Final Cut Pro Legacy › Can I convert 30P shot material into 24P?
Posted by Caton Clark on October 15, 2007 at 1:54 pmI’m working on a project where the majority of the footage was shot in 24P. However a few interviews were shot in 30P. I can barely see the difference but the people paying for everything want to see it converted to 24P.
I tried a quicktime conversion and didn’t see any difference and I’m not sure if that’s the right process.
Anyone know if there is another way to convert this footage from 30P to 24P?
Thanks.
Jeremy Garchow replied 18 years, 11 months ago 4 Members · 12 Replies -
Mark Maness
October 15, 2007 at 2:30 pmhttps://www.nattress.com/Products/standardsconversion/standardsconversion.htm
The filter set will cost you about $100 but very well worth it.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey -
Caton Clark
October 15, 2007 at 2:44 pmThanks for the response Wayne.
Sadly, I don’t think anyone here si willing to buy anything.
Is there anything I can do within FCP?
Thanks.
Mark Maness
October 15, 2007 at 3:12 pmYou could possibly use Cinema Tools for this or use you could use Compressor (but you might run into some sync problems). I’d look over the documentation for Cinema Tools and see what it says on this subject.
Wayne Carey
Schazam Productions
Caton Clark
October 15, 2007 at 3:30 pmOk, one more question.
I took it on faith that the material was shot 30P, since that’s what they told me, but I just looked at the clip’s item properties and it is saying the clip is lower field first / 29.97.
Would FCP make that conversion on capture or does that mean that the material was actually shot interlaced?
Thanks.
Mark Maness
October 15, 2007 at 3:37 pmSounds like the material was captured 29.97 Interlaced. You can do this. The material should have been captured at 30p.
Take a look at you 24p footage…. Does it say that its 23.98?
Wayne Carey
Schazam Productions
Caton Clark
October 15, 2007 at 3:48 pmThe material that was supposedly shot 24P is also coming up as 29.97 interlaced, which is what it looks like they set up the project to do.
Would it be best just to have them convert the tape? Or can we reload it at 30P and then export it at 24P?
The producers are seeing a slight difference in the quality between the 24P material and the 30P material, so basically i just need to find a way to make them look similar.
Thanks for all of your help.
Caton Clark
October 15, 2007 at 4:33 pmThe production manager just spoke with the shooter’s agency and it sounds like the camera he used had a setting that changed the look of the footage and converted it to 29.97 while the other camera people used a lower quality looking setting that the camera also converted into 29.97.
So it sounds liek there’s nothing i can do through FCP.
Thanks everyone for the help.
Arnie Schlissel
October 15, 2007 at 4:59 pm[cmc2008] “Sadly, I don’t think anyone here si willing to buy anything.”
That doesn’t leave them any options, does it? $100 is nothing over the cost of any production. If it’s they think it’s important to the look of the show, that’s probably the cheapest good option they have.
[cmc2008] “The production manager just spoke with the shooter’s agency and it sounds like the camera he used had a setting that changed the look of the footage and converted it to 29.97 while the other camera people used a lower quality looking setting that the camera also converted into 29.97.”
All standard def NTSC video is 29.97 interlaced. That’s not some arbitrary thing that FCP does, that’s a broadcast standard mandated by the US government. 24P & 30P are recorded to tape inside of an interlaced stream.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Jeremy Garchow
October 15, 2007 at 5:10 pmCMC, can you please tell me what kind of footage you are capturing from? Is it tape, tapeless, HDV, SD, Mpeg4, 3g cell phone, Security Cam.
Please?
