Activity › Forums › DaVinci Resolve › Can I continue to use my PVM and BVM monitors with Resolve?
  • Michaelmaier
    March 4, 2013 at 3:45 pm
    Ok. I guess the moderators lost my reply to Paul Provost as it was never posted. I guess I will have to reply again.
  • Michaelmaier
    March 4, 2013 at 3:46 pm
    So the 20L5 is actually HD? Although I’m not sure mine is a 20L5/1. I have never heard of a /1. What’s that? Do I need this specific version to work with HD 24p (23.976)?
    Also, what is the main difference between a 20L4 and 20L5? Would the 20L4 also work?
    Last, I know the BVM-20E1E and BVM-20F1U are probably the best CRT Sony ever made and I know somebody who has both sitting around without use who said I can have one of them, for free. Would that be better than all the others I mentioned?
    Thanks.
  • Paul Provost
    March 4, 2013 at 5:28 pm
    I think the L4 is SD only. I think the L5/1 was the 23.98 capable one, and you probably have to test to see if it works as I believe model number plate does not clarify. As for the bvm, google for manuals.
    http://www.4Kfinish.com | owner-colorist | Hollywood, CA
    http://www.facebook.com/4kFinish
  • Eric Hansen
    March 4, 2013 at 5:33 pm
    if you’ve never seen 23.98 on a CRT, it’s going to look weird and strobe, but this is correct. i would typically keep my L5 connected to the AJA Kona component output running at 1080i60, even for 23.98 material so the strobe wouldn’t drive me up the wall.
    e
    Eric Hansen
    Production Workflow Designer / Consultant / Colorist / DIT
    https://www.erichansen.tv
  • Michaelmaier
    March 4, 2013 at 5:43 pm
    In that case, if feeding it 60i, does it still need to be a L5/1? Or will a normal L5 work?
  • Eric Hansen
    March 4, 2013 at 5:48 pm
    I don’t know. all my HD-capable Sony CRTs could play 23.98 footage. but i don’t know if they were /1 or not. Sony doesn’t typically indicate on the unit if it’s a /1 version or not. I had a Sony M2000/1 HDCAM deck and you wouldn’t know it was a /1 by looking at it. after i received it and it didn’t say “/1” anywhere, i had to call Sony to make sure they sent me the correct unit. if i remember correctly, it was an internal board upgrade. not sure what makes the L5/1 monitors different than the L5
    e
    Eric Hansen
  • Michaelmaier
    March 7, 2013 at 11:13 am
    Thanks. Do you know if all 20L5 monitors are HD capable? Because I was just told that you need some extra card for that and I’m not talking about the SDI card. I thought they all were HD?
  • Eric Hansen
    March 7, 2013 at 3:37 pm
    AFAIK, they can all take HD over component. my current 14L5 doesn’t have any boards and i use component and it will see 720 or 1080. it just doesn’t have enough lines to display full 1080, but you know that.
    it does SD too 🙂
    e
    Eric Hansen
  • Michaelmaier
    March 7, 2013 at 4:05 pm
    Sure it’s not HD resolution. But 800 lines in a small 20″ size is enough. They say you need 24″ before you need full HD. Actually it’s 600 lines in 16:9. But it also becomes around a 17″ in 16:9 so it works the same.
    Good to know even without the SDI card it will do 1080 via component. Although I’m thinking for sure only 1080i and not 1080p.
    In any case I have an old Blackmagic SP card that sends 10 bit component HD which should work with it then. At least I think.
    Is there a special SDI card for HD or all SDI cards for the 20L5 will do both SD and HD?
  • Amir Qureshi
    July 16, 2014 at 9:49 am
    Hi Michael,
    I know I am diggin out an old thread, but was just curious, what did you end up doing?
    Thanks.
Page 2 of 2
