Activity Forums Compression Techniques Can I compress to a specific size?
  • Craig Seeman
    May 5, 2006 at 2:06 pm
    Depending what codec you’re using, Compressor 2 gives you an estimated size in the Inspectory Summary tab. You can make setting adjustments to hit your target size.
