Activity › Forums › Apple Final Cut Pro Legacy › Can I color correct master source clip after multicam?
Posted by Greg Mulvey on December 3, 2005 at 6:35 pmI just finished a multicam and realize that I need to color correct one of my sources. Is it possible to just go back to the orginal source clip that was used and color correct it and have those change update in the multicam edit that I did? Or do I have to now go to each individual clip in the multicam and apply the color corrections?
Greg Mulvey
Designer:Animator
https://www.gregmulvey.comOliver Peters replied 20 years, 9 months ago 5 Members · 7 Replies -
Walter Biscardi
December 3, 2005 at 7:17 pmI haven’t used Multicam yet, so I’m not sure on the original source clip thing.
but if you can’t do that, you can simply apply the CC to the first instace of that source in your timeline. Then do a “Copy” command. Then select all the other shots from that source, control+click and from the drop down menu select “Paste Attributes” then select Filters from the next window.
That will apply the same CC filter from your first shot to all the rest.
Walter Biscardi, Jr.
https://www.biscardicreative.com“The Rough Cut,” an original short film premiering December 7th in full High Definition in Atlanta.
rsvp@biscardicreative.com to reserve seats.
https://www.theroughcutmovie.comNow editing “Good Eats” in HD for the Food Network
Greg Mulvey
December 3, 2005 at 7:29 pmThanks Walter,
That is what I have been doing so far, but there must be an easier way to Color Correct in multicam mode! Avid has a great color correction mode for multicam, I hope Apple adds something like it in the future.
Greg Mulvey
Designer:Animator
https://www.gregmulvey.com -
Mike Debbie
December 3, 2005 at 7:35 pmI’m in the same boat as you buddy, and i believe we may have shot ourselves in the foot. One of the things I did try though was to color correct one of the angles, copy it in the timeline, then select the same angle where ever it appeared throughout the sequence and paste attributes (a window will pop-up, check the “filters” box) onto all the selected clips in one shot. Whatever color correcting changes were made on the first clip will paste onto all the clips that were selected. I tried correcting the source clip and didn’t see the changes in the sequence, so i think this might be the best way.
Walter Biscardi
December 3, 2005 at 7:40 pm[Greg Mulvey] “That is what I have been doing so far, but there must be an easier way to Color Correct in multicam mode!”
Well, one thing I do when I have a lot of clips, is simply select every clip that needs to use the filter and do the Paste Attributes one time.
Oliver Peters
December 4, 2005 at 3:40 pmYou might look at XM|Edit’s Traffic (www.xmedit.com). They are node based and one of the nodes is a filter copy/paste function. You can set clip trigger parameters, which means that you can apply a specified filter to all clips in the timeline with the criteria you define. It’s XML in and out and works quickly and easily. Might be worth trying for this situation.
Sincerely,
OliverOliver Peters
Post-Production & Interactive Media
Orlando, FL
http://www.oliverpeters.com -
Oliver Peters
December 5, 2005 at 2:34 amI ran a test with XM|Edit’s Traffic tonight and it does exactly what you want, which is to paste CC filters on all clips with a given name, such as Cam 1. One caveat is that it doesn’t seem to work with the Apple XML output from a multi-clip sequence. When I exported using the Automatic Duck XML export instead, it worked correctly.
Sincerely,
OliverOliver Peters
Orlando, FL
