Activity Forums Adobe Premiere Pro Can I change “step back/forward many” settings ?
  • Can I change “step back/forward many” settings ?
    Posted by Bryan Colvin on May 18, 2014 at 5:00 am
    I like Avid’s 1234 use for stepping through frames. 1 steps back 8 frames, 2 steps forward 8 frames.
    I like the 8 frames thing cause I know its a 1/3 of a second which I’m used to dealing with
    Premiere uses 5 frames to step, is there anyway to modify this to 8? I don’t like the 5 frame step
    thanks in advance!
    (I WAS able to modify the trim many to 8, but not the step back/forward to 8)
    Justin Crowell replied 11 years, 10 months ago 3 Members · 2 Replies
  • Peter Garaway
    May 19, 2014 at 4:38 pm
    Hi Bryan,
    In the NEXT Premiere Pro CC release users can specify a number of frames for the step forward/back.
    Here’s the blog post pointing out the other features that will be included.
    https://blogs.adobe.com/premierepro/2014/04/thenextpremiereproccrelease.html
    Peter Garaway
    Adobe
    Premiere Pro
  • Justin Crowell
    November 20, 2014 at 11:02 pm
    EDIT: Whoops, I found it! Odd that it’s in the playback tab….
    Was this ever included? I can’t seem to find it, or any mention of it in the documentation….
    Editor, Producer, DP
    JustinCrowell.com
