Can I change See-Through Tex to NON-See-through?
Hello all! Thank you for reading this as I’m sure it’s a dumb question:
It’s a little hard to explain so I’ll start from the top:
I downloaded a font that is block-text, like letterman jacket or something like that.
However, in After Effects, when put this text over the Video, the Font was revealed to be a stencil!
So the video plays through it and the font is essentially splines.If i put the font over a white solid, THEN the face of the font looks correct (white) but then how can I make it stay this way (font-face filled in with white) while still having it over the video?
Is there a way in AE, either through Keying, or whathaveyou, to make it so the “Face” of the font stays white? Thanks so much!
I’ve been experimenting for hours and haven’t found a solution.
