Activity › Forums › AJA Video Systems › Can I capture DV then convert it to DVCPro 50 on the Kona 3?
  • Can I capture DV then convert it to DVCPro 50 on the Kona 3?
    Posted by Tim Langston on June 24, 2006 at 4:38 pm
    Is it possible to capture DV and convert it to DVCPro 50 on the Kona3? Because I haven’t been able to do it.
    Tim
    Tim Langston replied 20 years, 3 months ago 3 Members · 3 Replies
  • John Ladle
    June 24, 2006 at 11:49 pm
    you sure can, but it must capture into the SDI of the Kona 3 card, not transfered via firewire. what kind of deck are you using? a JVC deck like the BRDV6000-SDI Professional DV Recorder with SDI Output Card for example. Also, the newer Sony and other SD decks have SDI output options.
    if you have an analog deck, converters like the HD10AVA or the D10AD can provide Analog to SDI.
    and of course, if you have another kona card, you can always output from one SDI and ingest to the Kona 3.
    those are 3 ideas, but in order to utilize the card for transcoding other codecs (or upconverting SD to 720 or 1080) it must come be captured through SDI.
    any of that help?
  • David Battistella
    June 26, 2006 at 11:30 am
    The other option if you do not have an SDI deck is to go the Media Manager route.
    1. Capture all of your DV firewire
    2. Use media manager to recompress to DVCPRO50
    3. Edit DVCPRO50
    David
    Peace and Love 🙂
  • Tim Langston
    June 26, 2006 at 2:39 pm
    Thanks, since my DVCam deck does not have SDI I’ll have to try and use the Media Manager method. I digitized D9 to DVCPro 50 today and it worked fine…through the SDI input.
    Tim
    Tim Langston
    Cryin’ Out Loud Productions
    Fort Wayne, IN
    http://www.colproductions.com
