Activity Forums Apple Final Cut Pro Legacy Can I capture 25P Directly from Varicam AJ-HDC27H?
  • Can I capture 25P Directly from Varicam AJ-HDC27H?
    Posted by Peter Corbett on April 19, 2010 at 2:06 pm
    I’m trying to capture HD-SDI directly from the Varicam into a Kona LHe from material shot in 25P on the Varicam into FCP7. The audio is late and the pictures are laggy. I’ve tried using a 720 50P preset to capture but it ain’t working. I was filling in while waiting for my NanoFlash to arrive, but I’ve got an awful feeling you can only get 25P into FCP via a proper DVCPROHD deck becasue of the 60fsp structure of the Varicam.
    Peter
    Peter Corbett
    Powerhouse Productions
    http://www.php.com.au
    Peter Corbett replied 16 years, 4 months ago 3 Members · 4 Replies
  • John Fishback
    April 19, 2010 at 3:13 pm
    Which Varicam are you using? Is the Varicam’s System Freq. set to 50Hz? We recently tested a PAL workflow with our HPX500. We used a PAL Easy Setup to L&T the clips into FCP. It worked perfectly. We were even able to view the footage on our HD monitor.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Peter Corbett
    April 19, 2010 at 9:45 pm
    John, I have the AJ-HDC27H which draws the 25P output from a 60Hz system frequency. It doesn’t have a 50Hz setting like the HPX500.
    Peter Corbett
  • Gary Adcock
    April 20, 2010 at 3:25 pm
    [Peter Corbett] “I’m trying to capture HD-SDI directly from the Varicam into a Kona LHe from material shot in 25P on the Varicam into FCP7. “
    you need to step back and give system, Os and Software versions info,
    are you using the Aja Kona 720p25 ProRes(Version) VFR setting?
    if not what settings are you using?
    you have confirmed that the camera is set to 60hrz and NOT 59.94 in the service menus
    Camera frame rate is set to 25?
    which video tap are you coming out of on the camera?
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Peter Corbett
    April 20, 2010 at 11:49 pm
    I got a detailed unsolicitored reply from John Thorn from AJA with steps for a solution. If it works out I’ll post the solution here.
    Cheers,
    Peter
    Peter Corbett
