Activity Forums Apple Motion Can I bring uncompressed .motn into AVID?
  • Can I bring uncompressed .motn into AVID?
    Posted by Beelaster on June 29, 2005 at 8:57 pm
    Hi-
    I’m looking for a way to bring Motion work across to an AVID Media Composer-big question, I know. Does anyone know the best way to do this? We will be using Automatic Duck for the FCP stuff, but this does not bear on Motion efx, right?
    The issue is that we are uprez-ing from DVCAM to D-Beta. Otherwise I would lay the rendered files to a hard drive and walk them over to the online studio, ’nuff said.
    There was a rumored Uncompressed Avid codec for Motion that was downloadable somewhere, but I have not been able to find it.
    Is the best way to go with the largest, most uncompressed QT codec as a safety, just in case?
    Thanks is advance for taking the time to reply- the Cow is the Bomb!
    Bee
    G5 dual 2.0/5.5gig/sonnet allegro FW800 PCI/3X250 LaCie FW800 extreme/AJA Io/Horita BSG-50/DSR-45/DSR-11/M-Audio Delta 1010LT/JVC Hi-Res Ref Monitor/stock Radeon video card/Prod Suite/Logic 7.1
    Beelaster replied 21 years, 2 months ago 3 Members · 3 Replies
  • Walter Biscardi
    June 29, 2005 at 9:42 pm
    Just render in the Animation Codec in Motion. That will import just fine into an AVID. Just be sure to render in the correct frame size and correct field order.
    I create a lot of animations in After Effects for an AVID editor using 720×486 frame size, lower field first and the Animation Codec. Works fine.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Jayson Steckler
    June 29, 2005 at 10:26 pm
    “There was a rumored Uncompressed Avid codec for Motion that was downloadable somewhere,”
    Is this what you were looking for?
    https://www.avid.com/onlinesupport/supportcontent.asp?productID=10&contentID=3555&typeID=
    Motion relies on QT for it’s I/O, There aren’t codecs specificly for Motion.
    Walter has a good point though, many simply use the Animation codec.
  • Beelaster
    June 30, 2005 at 12:56 am
    Gratitude!
    Thanks for the link and the knowledge!
    I’m almost done with this thing. Onlining tomorrow. Then I can swim in lakes.
    Bee
