Activity Forums Adobe After Effects Can I bake my time-remapping to new key-frames in the pre-comp.
  • Can I bake my time-remapping to new key-frames in the pre-comp.
    Posted by Adam Seeley on November 30, 2015 at 9:34 am
    Hi guys & gals,
    I have a large comp with many animations, key-frames and nested compositions.
    I had to change the timing across the main comp to start slow and ramp the speed up by the end.
    This re-timing has been approved now and the re-timed comp is about half the length of the old one.
    Is it now possible to bake the time-remapping info into the main comp so that I can drop the time-remapped version and fine tune the, now retimed, master comp?
    Obviously I just want to avoid having to shift everything by hand.
    Many thanks,
    Adam Seeley
    Adam Seeley replied 10 years, 9 months ago 54,352 Members · 2 Replies
  • Adam Seeley
    November 30, 2015 at 5:12 pm
    Hi Dave,
    Indeed, but that’s too final for me at this stage.
    The original comp is quite a heavy render so I don’t want to waste time over-rendering as such.
    Also, I still need to fine tune transitions etc. in what would be the re-sped version.
    I guess I need a clever script that will translate the time re-mapping to the keyframes in the pre-comp.
    (If anyone’s heard of such a thing).
    Adam.
  • Adam Seeley
    November 30, 2015 at 10:31 pm
    Nopedy nope, it still needs to be live.
    I have a long comp that has many layers and animations.
    To save time shifting loads of layers & keyframes around, I brought that master comp into a new clean comp and time-remapped the whole thing to create a speed ramp.
    The re-timing is approved (not the whole job),I still need to work on many aspects of the animation.
    I was hoping to bake the time-remapping to all the keyframes in the comp below.
    The more I think about it, the less likely it is to be possible.
    It would need a script to analyse each layer, apply the scaling of the time-remap values to the keys and plot frame-by-frame keys for all the animations.
    I mainly work in 3D and it’s not unusual to create layered animations on objects before baking the keys out to a simpler, single layer of animation.
    Thanks though,
    Adam.
