Activity › Forums › Adobe After Effects › Can I apply a stop motion effect to video?
Adrian Stiegler replied 6 years, 10 months ago 9 Members · 14 Replies
Matt Luckhurst
February 6, 2008 at 5:33 pmthanks for the link. that vid makes its easy, i’ve just got to fine tune it.
Emilie Stadlin
April 15, 2012 at 6:03 pmHi! I have exactly the same problem: i want to apply stop motion effect to a video, do you have any recomendation?
Christian Lopetz
June 2, 2015 at 5:33 pmIn Premiere I speed my footage to 200% and then use the posterize time effect at about 1/4 of my frame rate (ie, if the original footage was shot at 24fps, posterize the time to 6fps AFTER you increase the speed to 200%) This usually gives it a nice choppy “stop-motion” look for me. It also helps if you know you’re going to do this in advance, and you can shoot things a little slower than you would regularly. Hope this helps.
Adrian Stiegler
November 28, 2019 at 2:55 pmBUMP!
This is totally the answer. Effect -> Time -> Posterize Time
Dial in your target FPS, BOOM!
Cheers!
