Activity Forums Maxon Cinema 4D Can I add simulated lens filters to my cameras?
  • Mylenium
    September 24, 2006 at 12:20 pm
    Advanced Render offers some of this trickery, but frankly I don’t find it rather exciting or high quality. I’d rather apply a few compositing tags (object buffer)and do a multipass render so you can tweak everything in AE. If that’s not an option, then yes, you need to re-adjust all materials and tweak the built-in glow until it looks right.
    Mylenium
    [Pour Myl
  • Arndt Von koenigsmarck
    September 25, 2006 at 6:18 pm
    Some of these effects can be simulated by Post Effect filters such as LSD from 3D Attack or Pleasantville from Motion Gimmick. Just be sure that the plugins run with you version of C4D and check out the demos first (if available).
    Kind regards,
    Arndt von Koenigsmarck
    https://www.vreel-3d.de
    https://www.vonkoenigsmarck.de
