Activity › Forums › Adobe Premiere Pro › Can I add my choice of transition duration?
  • Can I add my choice of transition duration?
    Posted by Trevor Asquerthian on June 22, 2015 at 8:07 pm
    In Avid I can add an audio dissolve and it prompts for a duration (and start/end/centre on cut) – any way of achieving that in PPro?
    Seems that I have to add the default then modify. I can’t seem to save different durations as effect presets either
    Thanks for any help
    Trevor Asquerthian replied 11 years, 3 months ago 2 Members · 3 Replies
  • Massimo Alberto croce
    June 22, 2015 at 10:02 pm
    you can change the duration (not alignment). in the preference>general>video transition default duration.
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
  • Trevor Asquerthian
    June 22, 2015 at 10:04 pm
    [Massimo Alberto Croce] “you can change the duration (not alignment). in the preference>general>video transition default duration.”
    I figured that was all she wrote on this one…
    Turns out sometimes I want that default to be 2 or 3 frames, sometimes 3 or 5 seconds….
    June 24, 2015 at 3:05 pm
    To answer my own question… in case it’s any use to anyone… then there are two shortcuts to adding transition – ‘add default transition’ and ‘add audio default transition’ – the latter takes the audio transition duration from the prefs… so I can at least have a 1.5 sec and a 3 frame transition
