Activity Forums Apple Final Cut Pro Legacy Can I add a “shaking” effect using fcp?
  • Can I add a “shaking” effect using fcp?
    Posted by Jesse Wenger on March 21, 2010 at 4:12 am
    My frinds and I would like ot film some fight scenes and to make them look more intense we would like to have the movie “shake” quickly and subtly. We can do this by shaking the camera while we are filming, but I have tried it and it does not give it the effect I am looking for.
    Can I do this with Final Cut Pro? If not, what software would I use to add this effect?
    Bernd Fütterer replied 16 years, 6 months ago 7 Members · 7 Replies
  • 7 Replies
  • Jerry Hofmann
    March 21, 2010 at 6:00 am
    Post more description or an example of what you’re trying to do.
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Harry Bromley-davenport
    March 21, 2010 at 8:38 am
    Try Graeme Nattress’ free plugin “Earthquake” and fiddle around with the settings.
    Harry
  • Tom Wolsky
    March 21, 2010 at 10:21 am
    There is an earthquake filter in the recent versions of FCP, but it may be too aggressive. At low levels with a little keyframing it might work for you.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Jesse Wenger
    March 21, 2010 at 2:06 pm
    I’ve seen this effect being used in adobe after effects, I think that is the program I am going to use.
  • Tony Young
    March 21, 2010 at 4:25 pm
    If you’re going the AfterEffects route, there’s a plugin that might do what you’re looking for–Twitch, at videocopilot.
    https://www.videocopilot.net/products/twitch/
  • Chris Tompkins
    March 21, 2010 at 4:47 pm
    Just apply size and angle key frames to you clip. Rez up clip to 105% or something and tilt it a couple degrees and then snap back. You can copy the properties and apply to other clips once you have it the way you like it.
    Chris Tompkins
    Video Atlanta
  • Bernd Fütterer
    March 22, 2010 at 9:04 am
    “Genarts Sapphire Plugins” contain a filter called “shake”. It’s perfect! …but expensive…
    Bernd Fütterer
    Germany
    http://www.visiomotion.de
