Activity Forums Blackmagic Design Can HD card output HD and SD simultaneously?
  • Can HD card output HD and SD simultaneously?
    Posted by Sean Maloney on May 26, 2005 at 9:15 pm
    I just built a system (G5) around the Decklink HD card which has 2 HD-SDI outputs. I have one of them going to an HD Link to feed a 23″ LCD. Can the other be used to feed the SDI input on a SD broadcast monitor giving me previews of the full HD signal and a SD down-convert simultaneously? Is there any cheap and easy way to do this?
    Thanks, Sean
    Matt Dowling replied 21 years, 3 months ago 2 Members · 1 Reply
  • Matt Dowling
    May 27, 2005 at 5:17 am
    Hi Sean,
    The HD Pro card supports simultaneous HD/SD output. However the other DeckLink HD models do not.
    Cheers,
    Regards,
    Matt
    Blackmagic Design
