Activity › Forums › Apple Final Cut Pro Legacy › can final cut do this? + image stabilizer question
Posted by Andreas Karoliussen on November 9, 2005 at 4:29 pmHi I
Jim Kanter replied 20 years, 10 months ago 3 Members · 3 Replies -
Graeme Nattress
November 9, 2005 at 4:35 pmI don’t think you can add multiple transitions at once.
The image stabilizer in FCP doesn’t work very well. You can try http://www.lyric.com for one that works, or use After Effects or Shake.
Graeme
– http://www.nattress.com – Film Effects and Standards Conversion for FCP
Andreas Karoliussen
November 9, 2005 at 8:29 pmThats to bad regarding to the transitions,
Thanx for the quick response and the tips about Lyric.com
I will check it out;-)Andreas
Jim Kanter
November 9, 2005 at 11:14 pm1. Set the default transition to the transition you want to apply multiple times.
2. Put an In point in the sequence where you want the first clip to use the transition.
3. Select all the contiguous (adjacent) clips that you want to put the transition between.
4. Drag them from the Timeline into the Canvas and drop them on OVERWRITE WITH TRANSITION.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
