Activity › Forums › Creative Community Conversations › Can FCPx Interpret Footage?
Posted by Ryan Walker on June 22, 2011 at 9:01 pmDoes anyone know if FCPx can interpret footage like Premiere or After Effects? What if I want to take my 60p and interpret to 30p?
Thanks.
Ryan Walker replied 14 years, 10 months ago 4 Members · 6 Replies -
Jeremy Garchow
June 22, 2011 at 11:00 pmCinemaToolsX.
Oops doesn’t exist. You can use compressor to slow down your footage.
Matthew Celia
June 23, 2011 at 12:14 amYes, it will take footage shot in a different frame rate (say 60p) and if you drop it onto the 30p project, it will conform it. There is a menu option under the retime menu to do so as well I believe. I’m doing some tests and while some of the frame rate stuff I’m seeing is wonky, the scaling seems to be very good.
Ryan Walker
June 23, 2011 at 5:55 amGotcha….but as of right now, there looks like no way to interpret a single clip without changing a timeline?
Jeremy Garchow
June 23, 2011 at 1:55 pmIt doesn’t work that way in FCP.
You want to conform your clip from 60 to 30 for slomo, right?
Todd Wolfe
June 25, 2011 at 4:35 pmFCPX does do it without cinema tools. “Conform Speed” will do it. I just did it with 60d 60fps footage and it worked great.
Ryan Walker
June 25, 2011 at 4:48 pmAwesome thank you! This was exactly the answer I was hoping to see.
Thanks.
