Activity Forums Apple Final Cut Pro Legacy Can FCPro 5 Handle DVCPRO HD ?
  • Can FCPro 5 Handle DVCPRO HD ?
    Posted by Max Jackson on June 30, 2011 at 10:26 am
    Hi CC,
    I’ve got a project that requires 15 fps and FCPro 5 is the only thing that might work for the project.
    Before erasing my entire computer I was hoping to know if FCPro 5 can handle DVCPRO HD (1080i60), Linear PCM, Timecode fomrat.
    Is that so?
    Thanks a bunch for any feedback. 🙂
    Max Jackson replied 15 years, 2 months ago 4 Members · 4 Replies
  • Rafael Amador
    June 30, 2011 at 10:37 am
    [Max Jackson] “Before erasing my entire computer I was hoping to know if FCPro 5 can handle DVCPRO HD (1080i60), Linear PCM, Timecode fomrat.”
    Yes.
    No problem.
    [Max Jackson] “I’ve got a project that requires 15 fps and FCPro 5 is the only thing that might work for the project.”
    is your footage 15fps?
    rafael
    http://www.nagavideo.com
  • Jeremy Garchow
    June 30, 2011 at 10:53 am
    Dvcpro HD is fine. 15fps won’t work.
    What are you trying to do?
  • Chris Tompkins
    June 30, 2011 at 3:58 pm
    Edit full res/frame size/rate.
    Export “Current settings”
    THEN,
    Compress for delivery.
    Chris Tompkins
    Video Atlanta LLC
  • Max Jackson
    June 30, 2011 at 8:25 pm
    Hi everybody,
    My footage was shot at 30 fps, but with double frames. I’m not sure what the technical term is, but it’s like 1/1, 2/2, 3/3, etc. because my final cut is going to be in 15 fps, almost like a flipbook.
    I can’t edit in 30 fps and then change speeds for audio matching-sake.
    However, I’ve managed to get Premiere to interpret the footage though, so I’m most likely going to go with that instead just because my project is so left field.
    Thanks a bunch for all your feedback! 🙂
