Activity › Forums › Apple Final Cut Pro Legacy › Can FCP send TC to monitor?
Posted by Betsy Thompson on November 30, 2007 at 7:24 amIs there anyway to get my timeline timecode on my monitor?
It’s a Sony Trinitron monitor connected via BNC in an AJA card.
OS 10.4.10/FCP 6.0.1
Betsy Thompson replied 18 years, 9 months ago 5 Members · 6 Replies -
Shane Ross
November 30, 2007 at 7:29 amNot unless you either add the TC Reader filter to the footage, or export a self contained or ref QT movie and use AJA TV to display it. Or, if you route it thru a deck and then the deck to the monitor, and you happen to be outputting to tape at the time.
Or you can get an external TC reader…dunno what they are called, but I have seen them on some Avid systems I sat in front of. Knew that I had to set the router to it…
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.lfhd.net -
Betsy Thompson
November 30, 2007 at 7:48 amWell that’s what I expected I guess. I just didn’t know if there was a magical setting I was overlooking. Thanks for your help!
Naicams
November 30, 2007 at 12:18 pmthere is a thing called “big Time” by digital heaven. they have a demo you can try. maybe it
Mathieu Marano
November 30, 2007 at 2:22 pmIf you have a Kona card with the latest drivers, you can display the sequence timecode on your monitor.
You simply set the TIMECODE tab to Quicktime in the control panel of the Kona Card
Betsy Thompson
December 1, 2007 at 7:08 amWow! That worked. Thanks so much! I was really pessimistic about that one!
