Activity › Forums › Apple Final Cut Pro Legacy › Can FCP import large frame sizes and then pan and scan
Posted by Chris Huggett on May 1, 2007 at 11:00 amHi guys
I have some video footage shot at a high frame rate and with a large frame size of 1024×1024. They where recorded as a sequence of targas onto a HDD.
Is it possible to take these large targas into FCP, with out any image adjustment, and then pan and scan them to my 16×9 PAL frame size.
ChrisBen Holmes replied 19 years, 4 months ago 4 Members · 4 Replies -
Tom Wolsky
May 1, 2007 at 11:56 amYes.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Walter Biscardi
May 1, 2007 at 12:11 pm[Chris Huggett] ”
I have some video footage shot at a high frame rate and with a large frame size of 1024×1024. They where recorded as a sequence of targas onto a HDD.”Those frame sizes are quite small, keep in mind that 1080i HD is 1920×1080 and 2K film is over 2000×2000. FCP is resolution independent and can handle pretty much anything you throw at it.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”Read my blog! https://blogs.creativecow.net/WalterBiscardi
Chris Huggett
May 1, 2007 at 12:54 pmIm sorry to be pain, but can you point me in the right direction on how it is done. Im not the person who will be doing this and don’t know FCP at all, but the person who will be doing it, was having difficulty.
Chris -
Ben Holmes
May 1, 2007 at 1:04 pmChris
They sound like images of a high speed camera. Just guessing.
To import the targa sequences, open Quick Time Player, not FCP and select Open Image Sequence under the file menu. Select the first still frame, and QTP will do the rest – it will ask you for a frame rate (select your project frame rate)
Save as a quicktime (it will have the frame size and frame rate of the original) and import this file into FCP. Drop the clip into the timeline, and it will automatically resize to fit the sequence frame rate. Double click on it in the timeline, open the Motion tab in the Viewer window, and adjust the scale and position as required.
Best of luck
Ben
Editec Broadcast Editing Ltd
EVS & FCP specialists for live broadcast.
OB Server 1 HD – Mobile FCP editing done right.
