Activity Forums Apple Final Cut Pro Legacy Can FCP import an Adobe Premier project
  • Can FCP import an Adobe Premier project
    Posted by Trace Burroughs on September 1, 2010 at 5:49 pm
    I know you can export a FCP project as an xml file and open it in Premier but can you go in the other direction. Save a Premier project as an xml file and open it in FCP? Or maybe there is another method someone knows about.
    Trace Burroughs
    LME COLLECTIONS
    lme-collections.com
    Dennis Radeke replied 16 years ago 3 Members · 2 Replies
  • Jerry Hofmann
    September 2, 2010 at 12:41 am
    You might ask this question in the Premiere forum…
    But I’m sure it will export an EDL, which can be imported in FCP.
    Better yet if XML isn’t an option, (which it probably is), would be Automatic Duck (google it). That likely would be the best in any event.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Dennis Radeke
    September 2, 2010 at 12:11 pm
    With Premiere Pro CS5, you can import and EXPORT FCP XML as well as Avid AAF.
