Activity Forums Apple Final Cut Pro Legacy Can FCP do sub frame audio edits?
  • Can FCP do sub frame audio edits?
    Posted by Samuel Frazier on June 21, 2005 at 7:06 am
    I’ve tried but came up with nothing. Asked a FCP friend of mine and he said this was possible, but he couldn’t find out how.
    Is this possible on FCP and if not, is there some kind of work around? Thanks ahead of time for any help!
    Samuel Frazier replied 21 years, 3 months ago 3 Members · 8 Replies
  • 8 Replies
  • Martin Baker
    June 21, 2005 at 7:48 am
    You can’t do actual cutting at sub-frame level but you can set audio keyframes and slip the clip to 1/100 frame accuracy.
    Martin
    Digital Heaven, London UK
    ________________________________________
    Ten Final Cut Plug-ins for just $10 each
  • Samuel Frazier
    June 21, 2005 at 8:28 am
    Thanks for the input, I appreciate it. I’ll do some more research as I’m a newbie here (just finished rough draft of 1st FCP project). Practically speaking though, do you find it a usable workaround, or more of a hastle?
    Thanks again!
  • Jeff Handy
    June 21, 2005 at 3:04 pm
    FWIW, I do most audio editing in an audio editing package – not FCP. To date, I’ve been using Peak. However, with the new Suite, I’ll likely be moving to Soundtrack Pro soon. The advantages just appear to be too great to ignore.
  • Samuel Frazier
    June 22, 2005 at 5:11 am
    Thanks, Jeff, I appreciate that. The problem is I’m used to doing all audio stuff along with the video (sub frame edits, compression, 5.1 mixing, etc) in the nle. It’s a real advantage. Just wish I had some of these programs (Peak, Logic Pro 7, Soundtrack Pro) to experiment on and see if it would work for me.
  • Martin Baker
    June 22, 2005 at 6:54 am
    Yes, the capability that’s there is useful enough, certainly preferable to not having any subframe ability at all. I mix and finish audio for all my projects in FCP and find it OK but it would be much better if we had a mixer with track fx, sends, buses etc.
    Martin
  • Samuel Frazier
    June 22, 2005 at 7:05 am
    Thanks again, Martin. Yeah, that’s the hard thing. I come from a program that does all that you mentioned and I guess I’ve come to take it for granted.
    Maybe I’m alone in this, but where I’d like to see FCP go in future releases is in the audio direction and address things like you mentioned. I just don’t hear many other people talking about it.
  • Martin Baker
    June 22, 2005 at 7:09 am
    Out of interest, what NLE were you coming from? I’ve always found that audio is something that the majority of editors aren’t that interested in, so it doesn’t produce much buzz or feature requests. With Soundtrack Pro out now, I think that’ll start to change.
    Martin
  • Samuel Frazier
    June 22, 2005 at 7:46 am
    I’m sorry, I don’t mention it as when I do it seems people ignore me from there on. It’s Vegas and Sony now owns it (and part of why I’m concerned about its future). Does all I mentioned (5.1, buses, filters on tracks, buses, automatic mini fades on audio cuts to avoid the pop from not cutting on a cross, lots more). Version 6 just came out and added VST plugin support. Has great integration with Sound Forge if you need super fine tuning. Noise reduction is a good thing to do there for example. Just send you audio clip to SF, do your work, save it, and a new version (or “take” as they call it) of the clip will open back in Vegas. Press ‘t’ to cycle through any takes you’ve made of clips. Lots of people also make 3rd party plugins to speed along audio work like ‘scripts’ that automatically lower or ‘duck’ music during VO. This is more of a rough in, but saves a lot of time.
    Also, Vegas’s default is to have external video preview through firewire and audio via the soundcard. You can also add an external firewire sound card and everything stays in sync. If it ever goes off, it’s no problem to get back in sync. This setup is much more accurate and less noisy than the firewire out to my camera then to my speakers deal that I employ with my Mac Mini right now.
    I’m currently playing around with different edls and AAF export import b/t Vegas and FCP to try to setup a good audio workflow, but I haven’t had much time to experiment lately.
    Guess I believe in the saving that audio is 70% of the visual experience so I don’ understand why audio isn’t discussed a lot more.
    Anyway, I guess this is my gripe about FCP and something that I know can be handled better.
    Please don’t boycott me!!
