Activity Forums Apple Final Cut Pro Legacy Can FCP capture film transfer edge code stored in the user bits on HDCAM tape?
  • Can FCP capture film transfer edge code stored in the user bits on HDCAM tape?
    Posted by Drdeluxe on February 21, 2007 at 1:06 am
    I am about to digitize source tapes from my super 16mm short film telecine transfer.
    The spirit transfer was mastered to HDCAM at 24p. I would like to preserve the edge code of the film for a possible DI print back to film after the initial offline is completed.
    I will be using FCP 5.1.2 and have never had to consider original film edge code in addition to traditional TC for the final EDL.
    My colorist said the edge code of each role is automatically stored in the userbits (or UBits) of the HDCAM tape.
    Is Final Cut Pro capable of recognising the user bit data if so how can I aquire that when I capture the source material from tape.
    If not, how does one keep track of the user bits in relation to the EDL?
    Does anyone know? Your assistance in the matter would be greatly appreciated.
    Sincerely,
    Zach Freyer
    za**@*************ve.com
    Editor/Director
    Joseph Owens replied 19 years, 2 months ago 5 Members · 4 Replies
  • Rafael Amador
    February 21, 2007 at 1:14 pm
    Hi Zach,
    Normally the User-bits are generated when you record with a camera or Video-desk. Users bits are embed in the TC (Longitudinal TC or Vertical Interval TC). When you capture your footage with FC the Uers-bits are captured but, as long as I know, FC doesn’t give you any chance to use that information, not even to monitor that data. And when you export from FC a new TC is generated but you can not even set User-bits in it.
    About TC the only chance that FC gives you is to set the initial time.
    Cheers,
    rafael
  • Gary Adcock
    February 21, 2007 at 3:03 pm
    [drdeluxe] “My colorist said the edge code of each role is automatically stored in the userbits (or UBits) of the HDCAM tape.”
    I have never heard of a telecine actually adding edge code to a tape during transfer.
    Usually the telecine includes a flex file with the transfer that needs to be handled inside of cinema tools and that CT maintains that database.
    “Is Final Cut Pro capable of recognising the user bit data if so how can I aquire that when I capture the source material from tape.”
    No. but then neither can avid directly -both use specialized apps to maintain that data base.
    That being said my Kona Cards can read UB data but that has been limited so far in FCP to rp188 TC for variable frame rates/ 24p.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Steven Gonzales
    February 21, 2007 at 3:17 pm
    Horita has some software called PC-LOG that captures time code or user bits. Perhaps you could use that to collect timecode to user bit (keycode), then match that to information from a Final Cut batch list somehow.
    https://www.horita.com/
  • Joseph Owens
    February 21, 2007 at 7:31 pm
    In order to extract the VITC-imbedded metadata (which can include keycode footage numbers, record tape TC, and external audio system TC), you usually require a device such as an “Afterburner” which will spit out the numbers.
    In your case, you should be able to use Cinema Tools to import the metadata (.FLX) file which should have been generated with your transfer. That data will appear as the secondary codes in FCP.
    It is correct that telecines do not insert metadata into the video stream. An onboard (on the telecine) keycode reader (Aaton or Evertz) looks at the barcodes as they fly past — and send that to a downstream key/insert box which becomes an external VITC source, inserted instead of the videotape recorder’s internal VITC generator. Getting these codes correct and in sync can be quite complicated, given the internal frame delays, etc., that can be associated with digital signal paths, recorders, noise reducers, and so on.
    Joe
