Activity Forums Apple Final Cut Pro Legacy Can FCP be trusted to create OMFs?
  • Can FCP be trusted to create OMFs?
    Posted by Michael Black fcp on July 30, 2009 at 1:32 am
    So we’re in the middle of mixing our second movie (first is already laid off and mastered to tape) and we’re finding a problem that occured in the first one that we sort of dismissed as something that couldn’t be helped. Now that we’re in the mix on our second picture, this same problem is cropping up and I need to get to the bottom of it.
    Namely, a lot of our dialog is getting distorted at some point in the process of either going to .OMF or the import into protools from .OMF. Right now, it’s not very clear where the problem is. But I guess my question is, has anyone else had an issue going from FCP to .omf to ProTools? I can’t really describe the “distortion” but it’s not happening in the .wav files that the .omf is being created from.
    We’re going to create a dialog stem of the mix thus far (we were supposed to layback tomorrow – that’s not happening) and check it against the edit, then create a new .omf with those problem files. But are we just going to have the same problem again? Is this something that Final Cut can’t do? I’ve worked on plenty of other features with Final Cut and not encountered this, but maybe there’s some factor I’m overlooking. Any ideas?
    MDB
    John Pale replied 17 years, 1 month ago 7 Members · 12 Replies
  • 12 Replies
  • Michael Black fcp
    July 30, 2009 at 1:54 am
    This seems to be limited to our dialog only.
  • Michael Gissing
    July 30, 2009 at 2:04 am
    An OMF can contain clip gain info which ProTools may be misinterpreting. Try exporting the OMF without gain, dissolves panning etc and see if you get a clean import.
    I never have this issue with FCP OMFs into Fairlight so there is likely to be an import setting within ProTools that isn’t being correctly set. Gain should be a virtual setting so what happens when the imported OMF has all the clips reset to zero gain?
  • Michael Black fcp
    July 30, 2009 at 2:10 am
    I always uncheck all the boxes pertaining to levels and panning when exporting the .omf. I’ll mention those settings to the sound supervisor though. Thanks!
  • Vince Sanchez
    July 30, 2009 at 3:07 am
    I bring in OMFs of 1 hr shows to Digital Performer at least twice a month and have never had a problem like that. Never use gain or pan on output.
    Vince Sanchez
    Intel Quad Mac 2.66
    AJA LHe
    HD link
    OSX 10.4.11
    FCP Studio 2
  • Mark Raudonis
    July 30, 2009 at 5:56 am
    Five years, hundreds of hours of television productions… never seen what you’re describing.
    Have you done tests to try to isolate where this is occurring?
    Mark
  • Walter Biscardi
    July 30, 2009 at 8:14 am
    [Michael Black FCP] “Namely, a lot of our dialog is getting distorted at some point in the process of either going to .OMF or the import into protools from .OMF. Right now, it’s not very clear where the problem is”
    We create OMF’s all the time for all our broadcast work and independent features for sound mixes on ProTools. Been doing this for about 5 years now. Have never seen anything like you describe. All audio is clean on the send to our sound designer and clean back from him. He’s in another facility and we work with everything via internet upload.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    Credits include multiple Emmy, Telly, Aurora and Peabody Awards.
    Owner, Biscardi Creative Media featuring HD Post
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Read my Blog!
    Twitter!
  • Michael Black fcp
    July 30, 2009 at 5:19 pm
    That’s what I thought. I’ve never seen this in ‘lo my many years of using FCP. But you know, the guys at the mixing facility (which I won’t name, but may or may not rhyme with Bony) just love to put down FCP when they can and are always quick to blame FCP.
    “So, when you exported out of your Avid…”
    “Final Cut.”
    “Final Cut?”
    “Yeah we use Final Cut.”
    “Oh well, if you’re using Final Cut…”
    I’m going to try another couple tests. See if I can’t get to the bottom of this.
    mb
  • Michael Black fcp
    July 30, 2009 at 6:37 pm
    I’m trying to import the OMF we created originally into Soundtrack and… not much is happening. There’s a progress bar that’s BARELY moved in a half hour.
    I tried to create a small OMF, one with just five tracks of audio spread out over about 12 minutes and it’s not going any faster. Is this common?
  • Mark Raudonis
    July 30, 2009 at 9:44 pm
    Sounds like you have some engineers predisposed to find a problem with FCP.
    I can’t stand A holes like that. I usually make a point of naming names to the facility owner
    when we take our business elsewhere. “We really would have liked to stay here, but your “engineer”
    {A hole engineeer name goes here} just couldn’t seem to handle our technical requirements. Funny, but
    XYZ facility was able to handle the same media with NO issues. See ya!”
    In this type of economy, I guarantee that you will get much better service at the “other” facility. Especially if you make it a point of letting the new facility know why you’re there.
    I really don’t know the cause of your problem, but it sounds like they are being less than helpful trying to
    trouble shoot. Good luck.
    By the way, I’ve had wonderful experiences at “Juniper Post”, “Matchframe Video”, and “Modern Videofilm”, all with OMF’s generated from FCP. Keep them in mind next time you’re shopping for a stage. And of course, in house we’ve been doing this for years.
    Mark
  • Mark Raudonis
    July 30, 2009 at 9:48 pm
    Oh, forgot to add “Oracle Post” to the “Wonderful to work with” list. (Excellent in house chef too!).
    Mark
