Activity Forums Adobe Premiere Pro Can Encore Markers be Automatically Set in PPro 5.5?
  • Can Encore Markers be Automatically Set in PPro 5.5?
    Posted by Thomas Smith on July 2, 2011 at 4:41 am
    I want to set an Encore Marker for every clip in a sequence, automatically.
    I am archiving about 80 mini-DV tapes to an external drive. I am trying to develop a sane workflow to do this. Here is what I have decided so far. Name a new project with the tape’s number. Import via FireWire using scene detect. Here is where the ability to set Encore markers would come into play. I will also use the Timecode effect. Burn a DVD. Use the archive function to export the project to external hard drive.
    Then sit down in front of the TV, play the DVD, take notes of clip content & timecode for each “tape”. Here is where the ability to have each clip be its own DVD chapter would come in. As soon as I know enough about a clip, I could use the remote to quickly go to the next clip, er chapter, and log the entire project comfortably.
    Any ideas?
    Thomas Smith replied 15 years, 2 months ago 2 Members · 2 Replies
  • Chris Knight
    July 2, 2011 at 2:35 pm
    This functionality was removed when Encore was added to the CS suite (prior to that, Premiere burned DVDs directly).
    You could always add a keyboard shortcut to the “Assign Encore Marker,” (under EDIT menu-> Keyboard Customization) and just keep hitting that key after PAGE DOWN (which jumps you to the beginning of the next clip). It’s not automatic, but you could add a marker or two every second, significantly speeding up this process.
  • Thomas Smith
    July 2, 2011 at 6:51 pm
    Thanks for the keyboard shortcut idea, that would significantly improve the workflow. I guess I was hoping that there was a way to run some kind of script or expression (like After Effects) to automate this. I have not run across anything so far.
